what motor oil is everyone using?
ctbob
Post by ctbob »
Hi All, what motor oil is everyone using? Also what brake fuild dot 3,4 or 5?Thanks Bob
manoa matt
Re: what motor oil is everyone using?
Post by manoa matt »
Motor oil: Shell Rotella T 15W40
Brake fluid: Whatever stops the car. Dot 3 is good enough.
courtenay
Post by courtenay »
I use Castrol 15/45 Diesel oil. Has the zinc content need for our engines. No idea on brake fluid.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
wikkid
Post by wikkid »
A note on brake fluid - DOT 4 is compatible with DOT 3, but DOT 5 is a silicon-based, not a glycol-based chemical that is absolutely not compatible with 3 or 4.
The really stupid thing is that DOT 5.1 is back to glycol, and compatible with 3 or 4 systems, but NOT with DOT 5!!!
I'm not sure when DOT 4 or 5.1 came out, but DOT 3 was probably the prevalent fluid at the time most, if not all, of these cars were made.
Foster48x
Post by Foster48x »
Same as Matt.
Shell Rotella T 15W40 and DOT 3 brake fluid.
Rick
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
Ditto on Rotella T. Works in my PowerStroke too!
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
mdrburchette
Post by mdrburchette »
Rotella has reduced it's ZDDP content for the newer style diesel engines. You guys may want to investigate this. I have been using Royal Purple in my gokart engines with very good results. After reading a little more about it, I may just use it in my Fiats as well:
http://www.royalpurple.com/faqs-motor-oil.html
baltobernie
Post by baltobernie »
Collector's Choice 30W
http://www.hicksoils.com/pdfs/10-13-09/ ... %20PDS.pdf
OTR diesels now have catalysts too, and their new oil spec reduced levels of zinc and phosphorus.
Other oils acceptable for our engines are ENI 20W-50 racing oil, Castrol GTX 20W-50, and Valvoline Racing 30W.
Mark also sells an additive shot for use with modern oils.
There are about eleventy-two threads on this subject, and Google will deliver a million more.
mdrburchette
Here's another type we all might be interested in:
http://www.bradpennracing.com/Zinc.aspx
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
valvoline durablend 20w-50w... I had been using valvoline 20w-50w racing oil for years... I tried the durablend and I think it is better. I use it in my old toyota 4runner definately an improvement there as it has high miles...I will probably try it in my v6 next... as for brake fluid not too picky there just dot3... :)
Rob
http://www.v6spider.com
eddy314
Post by eddy314 »
Castrol Syntec, full synthetic. I understand its got all the additives you need.
SLOSpider
Post by SLOSpider »
30wt Chevron - for breakin period.
15/40 Delo is the best all around I think
Dot 3 or 4 fluid for brakes
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
kilrwail
Post by kilrwail »
mdrburchette wrote:Here's another type we all might be interested in:
I use Brad Penn 20W50 in both the Fiat and Porsche engines. It comes highly recommended. It's the former Kendall GT green oil.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
wikkid
Post by wikkid »
Hmm - I am seeing a lot of folks using 20w50..... but I thought Fiat manuals spec 15w40. I'm new to Fiats, so could any of you 20w50 users enlighten me? I use 20w50 motorcycle oil in my V-Twin motorcycles - never thought of using the same thick, heavy grade it in a car.
baltobernie
The 1800 engine, for example, cAlls for 30W or 20W-40. Not much available in 20-40, so folks use 20-50
