ground pods
- Your car is a: 1969 124 Spider Convertible
ground pods
I don't know if my term is correct, but saw they were referred to as pods and are located under hood on both sides of compartment. My question is, in removing wire, the end not visible, is it a connection that I should just be able to slide out, or is the wiring soldered? I just don't want to make a mistake, thank you.
Re: ground pods
Not sure I understand your question, but if the wire is on a ground pod, then it should have a female connector and you should be able to remove it.
- Your car is a: 1982 Spider
Re: ground pods
Mik
The pods and wires are visible. If you are trying to remove a wire for which you do not see the connection, it is probably not a ground wire at a pod.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
