side marker lights
mik
Your car is a: 1969 124 Spider Convertible
side marker lights
Post by mik »
Can someone help me find the bulb housing that attaches to the side marker lights? One on rear left drivers side works, right front passenger side wire without housing. Left front and rear right have the housings, but can't get bulbs to light. Any help would be appreciated. Is there a good supplier out there I could use? Have been using IAP.
james124
Re: side marker lights
Post by james124 »
Have you tested the bulbs to make sure they are good? Those bulbs are generally available at your local auto shop. If you don,t have power to the housing, the first thing to check is the grounds - clean solid connection. If you need parts for marker lights, post your needs in the parts wanted section, or check with NJFIAT1981. Let us know how you make out. Cheers, James
mik
Post by mik »
Thanks James, just bought the bulbs. Checked to see current is getting to the housing, and it is. Will do a good cleaning of the housing and connector. Hopefully that will work, I will need parts and will post. Again thanks for the help
