brake booster
brake booster
Hey y'all.... I just bought a 1978 Spider and now there is a big leak in the brake booster, which seems to be coming from behind the brake pedal on the black rubber boot. Every time I try to brake, it doesn't and accelerates instead. I am looking for the best most inexpensive solution to this problem. I am also looking into the manual conversion. Any suggestions would really be helpful. Thanks and I hope to hear from some of y'all soon.
- TulsaSpider
Re: brake booster
Well you will have to find a replacement booster or like you said, do the conversion. Maybe someone has a good used one??
