Remove EGR
dcarey
Remove EGR
Post by dcarey »
I am in a state that does not inspect for emmissions on '70s era cars. I have a 1978 Spider and intend to remove the EGR and the air compressor system but keep the evaporation cannister.
Does anyone have a task list for how to proceed?
Re: Remove EGR
pretty straightforward. You need 12mm x 1.25 plugs for the air injection rail. The egr tube in the intake has an allen inside of the first allen plug you'll remove. The hard part is finding a plug for the intake manifold. If you emission stuff is still working, consider offering it for sale. Emission states like Calif still require those parts
dcarey
Re: Remove EGR
Post by dcarey »
Thanks. The Weber 32 ADFA has around 8 lines in addition to the fuel supply and return. Does anyone have a schematic or explanation of which ones I can blank off?
Re: Remove EGR
the only ones you need are for the crankcase breather and evap cannister
