I am replacing the 13" wheels and tires with 14" panasports that I bought from IAP. The new wheels wouldn't fit on because the original equipment steel wheel used 2 alignment posts per wheel to hold the wheel in place while I put the bolts in.
However, I removed the alignment posts, but a 1/4" spacer came off. I am trying to find a screw with the same threads and a flat head of some kind to hold the plate on, but nothing is available that I can find. Does anybody have any Ideas?
Just for your info., I purchased this spyder new in "69 for $3,450.00. It has 28,250 miles, all mine, and because 4 children seemed to drain most of my cash, this car just sat in my garage till now. I did have it inspected in 1971,1978, and the last time in 1991. In the beginning, it was my only transportation, then I married, and my wife's 1969 Volkswagen (with an Abarth muffler system) became the family car. My older brother bought a 1973 spider, and my son has made a down payment on a 1982 spider, so now I have to get mine back on the road. I hope I didn't bore anybody.
Let me know if there is an answer out there.
Fifth Kid
1969 spyder wheel spacer
Re: 1969 spyder wheel spacer
Wow, your story is awesome! The original owner of a 69. I'm impressed you kept it so long.
As for your wheel problem. I just cut my locating studs down to accomodate the aftermarket wheels I put on my 72.
- DUCeditor
- Your car is a: 1977 FIAT 124 Sport Spider
- Contact:
I faced the same issue when I put Panasport 14 inch wheels on my spider back in `89. My solution... Each time I have to resinstall the wheels - i.e., whenever I rotate or replace the tires - I simply put the spacer in place and hold it with the first bolt rotated to the twelve oclock position.
It is a nuisance, yes, but one that I've lived with for twenty+ years.
-don
-don
Italian motorcycles. An Italian car. An Italian wife. What more could a man desire?
- courtenay
I also left the locating studs off when I put the US Indy mag wheels on my '72. Makes it a bit tougher to line up the holes for the wheell studs, but they do hold the spacer on. Is there a way you could go to a stud/nut combo to hold the wheels on rather than the existing bolts? Then you could simply hang the spacer and the wheel on the studs and bolt it on.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
