73 Fiat Spider 2.0
SLOSpider
Re: 73 Fiat Spider 2.0
Post by SLOSpider »
Trouble in paradise...again. timing belt too long. Great so now what so we have. NO numbers on block other than cast into it 132ABO 263870. Both stamp locations are blank. Is it a 1600 stock motor? Does a 2.0 Head fit on a 1600? Is it and 1800 that was swapped with the 2.0 FI stuff? The new timing belt had part #4371507 on it the old one has #4182426 and the new tensioner bearing is a bit larger that old one.
Wondering if I should just take my 1800 spare engine and stick it in there and put the manifolds on it instead. Lucky so far I have not installed the intake yet.
On a side note this is how I got the nut off the crank shaft. A wobble extension and 130 psi with impact. Couple of brapps and it was off. Tried a pipe method - useless. I did have the left side sitting ontop of the mount stud as I did that to get the intake out and also rear trans support is out to change its mount so the engine tilting back helped.
Also found seal wear in the gear shaft. Should put a seal saver on it but I cleaned it up and we will see how it goes. Has to put a sleeve on the aux shaft on the last motor due to this kind of wear and still leaked oil even with a new seal . If you have the time its best to use a sleeve and save you some heart ache down the road.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
vandor
Post by vandor »
The old timing belt p/n is for a 1600/1800 belt.
The crank timing gear in the pic is a pre-76 type, so both of these show that it is definitely not a 2000.
If the block says '132' then it's either a 1592cc or 1756cc. A 2 liter head would fit on either, but it would lower the compression ratio.
SLOSpider
Post by SLOSpider »
vandor wrote:The old timing belt p/n is for a 1600/1800 belt.
Great, add fuel injection and lower the compression. I wonder why they didn't stick with just leaving the 1600 head and putting the FI manifolds on it?. Without an engine # I don't even know if its a 1600 or 1800. Hum, I don't know what to do now. Sent you an email about the belt and tensioner. Looking at the parts it only shows one style of tensioner bearing. Are they larger now. I guess Ill just get the stupid thing running again and come up with a game plan to maybe just stick my spare 1800 engine in at some point. Why do people do crazy swaps like this.
1975 124 Spider
SLOSpider
Post by SLOSpider »
Not a football fan so today I got the single reservoir and new blue hoses connected to the new master, add brake fluid and got brakes now. At some point I will go thru the whole brake system.
I thought I would try to remove the pumpkin and axles to see where the metal bits came from I found when draining the rear axle. But no luck as my super heavy duty snap ring pliers were no match and broke the ear off the too. Ill have to find another pair that will stand up to it. I put it back together for a rear end swap in the part car another day. Drain the trans and it looked really good and nothing surprising cam out of it. Went to get my GL1 90 and could not find it. Must be hiding or I gave it to my friend for his Fiat as I didn't think I would be buying another anytime soon.
Removed the doughnut and trans mount. The taller mount I got looks way too tall to put it back in so Ill order the stock one and see how it goes.
Got to place ANOTHER order for the parts to get this thing going with the correct timing belt and mount. Im sure Ill order more while Im there browsing.
Who won?
1975 124 Spider
vandor
Post by vandor »
There must be something stamped somewhere...
Only the 1438TC tensioners are different, all the others are the same diameter. Until '79 or so they were narrower, but then Fiat came out with the wider version and superseded the wider one for all the 1600/1800 engines too.
So as long as it's not a 1438, the tensioner will work. Based on the part number on the timing belt, it's a 1600 or 1800.
SLOSpider
Post by SLOSpider »
Ok thanks for that reply. I can take a pic of the tensioners if needed but both of the old ones I have are smaller diameter than the replacement. Also just found out the intake gasket I got has a T shaped middle water port. My old one is just an oval and would be better than the T style to seal up that area. Ill give you a call in the morning.
Thanks Brian
1975 124 Spider
SLOSpider
Post by SLOSpider »
Nothing. Almost like someone want them to think it was a 2.0 in there...fishy
1975 124 Spider
vandor
Post by vandor »
The second pic is the area just above the oil filter block? That's where a 1600/1800 would be stamped.
SLOSpider
Post by SLOSpider »
Yes that it. The other is above left motor mount. Even removed the fuel pump block off plate to check above there, nothing. Must have been ground off at some point?
1975 124 Spider
SLOSpider
Post by SLOSpider »
Just thinking, Is it possible its lower and they changed the 2.0 oil filter housing to this block and its blocking the numbers?
1975 124 Spider
vandor
Post by vandor »
I don't think so.
rodman
Post by rodman »
This is where on the intake side of my 2.L are the numbers
Untitled by fiatcs2000, on Flickr
narfire
Post by narfire »
Isn't the 2L block a bit higher/taller than the 1800? The timing belts are different.
I think you had a 1800,perhaps measure the block only height on each.
Chris
SLOSpider
Post by SLOSpider »
Those are the cast numbers but the true numbers are STAMPED in the flat portion just above the oil filter housing or flat portion just above left motor mount.
1975 124 Spider
rodman
Post by rodman »
SLOSpider wrote:Those are the cast numbers but the true numbers are STAMPED in the flat portion just above the oil filter housing or flat portion just above left motor mount.
you can still see what motor you have with the casting number
Engine Series Type Volume Bore Stroke C.R. Valve Timing Intake Emissions H.P.
100G3.002 OHV 817cc * * * * Carb. None *
100GBC.040 OHV 903cc * * * * Carb. Federal *
100GBS.040 OHV 903cc * * * * Carb. Federal *
100GC.000 OHV 843cc * * * * Carb. Federal *
100GC3.040 OHV 817cc * * * * Carb. Federal *
100GS.000 OHV 843cc * * * * Carb. Federal *
100GS3.040 OHV 817cc * * * * Carb. Federal *
124A.000 OHV 1197cc 73.0mm 71.5mm 8.8:1 25-59/65-19 Carb. None 60
124A.040 OHV 1197cc 73.0mm 71.5mm 8.8:1 25-59/65-19 Carb. Federal 60
124AC.040 DOHC 1438cc 80.0mm 71.5mm 8.9:1 26-66/66-26 Carb. Federal 90
124B2.040 DOHC 1438cc 80.0mm 71.5mm 8.9:1 26-66/66-26 Carb. Federal 90
125BC.040 DOHC 1608cc 80.0mm 80.0mm 9.8:1 26-66/66-26 Carb. Federal 110
128A.040 SOHC 1116cc 80.0mm 55.5mm 8.8:1 12-52/52-12 Carb. Federal 49
128A1.031.5 SOHC 1290cc 86.0mm 55.5mm 8.5:1 10-54/54-10 Carb. California 51
128A1.040 SOHC 1290cc 86.0mm 55.5mm 8.9:1 12-52/52-12 Carb. Federal 51
128A1.040.4 SOHC 1290cc 86.0mm 55.5mm 8.5:1 10-54/54-10 Carb. Federal 51
128A1.040.5 SOHC 1290cc 86.0mm 55.5mm 8.5:1 10-54/54-10 Carb. Federal 51
128AS.031.5 SOHC 1290cc 86.0mm 55.5mm 8.5:1 12-52/52-12 Carb. California 52
128AS.040.4 SOHC 1290cc 86.0mm 55.5mm 8.5:1 12-52/52-12 Carb. Federal 54
128AS.040.5 SOHC 1290cc 86.0mm 55.5mm 8.5:1 12-52/52-12 Carb. Federal 54
132A.040.4 DOHC 1592cc 80.0mm 79.2mm 9.8:1 26-66/66-26 Carb. Federal 104
132A1.031.5 DOHC 1756cc 84.0mm 79.2mm 8.0:1 5-53/53-5 Carb. California 83
132A1.040.4 DOHC 1756cc 84.0mm 79.2mm 8.0:1 5-53/53-5 Carb. Federal 86
132A1.040.5 DOHC 1756cc 84.0mm 79.2mm 8.0:1 5-53/53-5 Carb. Federal 86
132AC.040.3 DOHC 1592cc 80.0mm 79.2mm 8.0:1 22-70/70-22 Carb. Federal 87
132C2.031 DOHC 1995cc 84.0mm 90.0mm 8.1:1 5-53/53-5 Carb. California 80
132C2.040 DOHC 1995cc 84.0mm 90.0mm 8.1:1 5-53/53-5 Carb. Federal 86
132C3.031 DOHC 1995cc 84.0mm 90.0mm 8.1:1 5-53/53-5 F.I. California 102
132C3.040 DOHC 1995cc 84.0mm 90.0mm 8.1:1 5-53/53-5 F.I. Federal 105
138A2.031 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 Carb. California 66
138A2.040 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 Carb. Federal 67
138AS.031 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 Carb. California 66
138AS.040 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 Carb. Federal 67
138B2.031 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 F.I. California 71
138B2.040 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 F.I. Federal 72
138BS.031 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 F.I. California 71
138BS.040 SOHC 1498cc 86.4mm 63.9mm 8.5:1 10-54/54-10 F.I. Federal 72
