IDF Carb Tuning Guide
maytag
Re: IDF Carb Tuning Guide
Post by maytag »
thanks for the offer! I'll take you up on it.
Which time zone you in?
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
Central - Houston, Texas
sptcoupe
Post by sptcoupe »
Dan - For some reason the email I sent bounced, but the jets you needed were mailed today and will be there by noon tomorrow. I also inlcuded a set of F9 emulsion tubes so you have more flexibility in dialing in the carbs.
maytag
Post by maytag »
weird.
I received two emails from you. did you send more?
sptcoupe
Post by sptcoupe »
Just those two - and I received your response as well. Not sure why it gave me that notice.
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Just looking through this post, what model Holly fuel pump are folks using? There are many "blue" models
Never mind - same performance specs - just newer model # :oops:
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: IDF Carb Tuning Guide, Dual IDF fuel economy?
Post by RoyBatty »
Just a check on what to expect or how others are doing.
I have made several trips from the Central Valley over the Altamont into the SF Bay Area with my dual IDF's and seem to be averaging about 21 MPG. Keep in mind, I am not driving it for best economy, I hold the gears longer than I probably should and rev the piss out of it when the traffic allows. Lots of fun.
I am not at all complaining as this is the same fuel economy I was getting with the EMPI 32/36.
The plus side is the sweet sound and the extra power I gained.
sptcoupe
Post by sptcoupe »
That sounds about right, but if you are careful and on a freeway you can eek out 25 or so. I get about 21 from my 2.0L with 44 IDFs on it. I can also get it down to 18 or so if I am having fun.
RoyBatty
Post by RoyBatty »
I was thinking the same, If I could only back off the throttle and cruise at a lower speed.........
But for some reason, it never happens.
I may have to do an economy run sometime to see just how much mileage I can get by driving like a stodgy old adult, instead of like a 50 yr old teenager.
sptcoupe
Post by sptcoupe »
And so why on earth would you want to do that? You can get the mileage you want driving a modern appliance. When I get into one of the vintage FIATS I'm driving a CAR!
RoyBatty
Post by RoyBatty »
Hey sptcoupe thanks for bringing me back to my senses! :)
Ever notice that it seems to be more fun to do a slow run up thru the RPM band as you go thru the gears? Due to the sounds that the induction makes as you accelerate.
More fun to me anyway that trying to do a light to light race with rushed shifts. 8)
sptcoupe
Post by sptcoupe »
Glad to see you back on track! I thought we had lost you there for a moment. I can't think of a sound I like more than dual Webers on a Lampredi TC. For me, cruising at about 5500 - 6000 rpms is the sweetest music there is.
PininF
Post by PininF »
Great reading exactly what I needed !
Need advice.
The car has been sitting for over 3 weeks without starting up…have just finished installing a new fuel filter by Filter King , waited a little while and turned over the key , the car started first go this has never happened before so was very happy can't say it was because of the new filter but hey first impressions are always the best !
Went on to install a new fuel pressure gauge ,again started first go so thought this is great…hoping to see the gauge idling to adjust fuel pressure but nothing at all…:( Any idea's ?
Cheers.
sptcoupe
Post by sptcoupe »
So the gauge isn't moving when at idle? Have you tried making an adjustment one way or the other (preferably toward higher pressure) to see what happens?
PininF
Post by PininF »
Yes tried that already , drove the car the other day without problems fuel flow was very responsive much better than before still the gauge doesn't work maybe it's just faulty will replace it over the weekend see what happens.
