Majic, if you're trying to quote ME saying this, then you've still got it wrong!majicwrench wrote:Vacuum does not "increase steadily to a point then goes to nil at WOT".
The only way to accel under high vacuum conditions is to be going down hill with throttle closed.
Keith
Vacuum will never increase as you open the throttle, just as you've described. Of course it drops. But if you are "casually" accelerating, as most of us do in every day driving (and I'm not talking about when you're leaving a dead-stop) then you WILL have vacuum. And I never used the phrase "binary switch". Here's what I DD say:
And of course I still stand by that.Maytag wrote: it is true that the wider-open the throttle, the less vacuum will exist, to the point of zero vacuum under WOT load.
