More progress
Locked
124JOE
Re: More progress
Post by 124JOE »
clean!!!!
azygoustoyou
Re: More progress
Post by azygoustoyou »
I have the clutch and flywheel removed. I tried to turn the pilot bearing when they were together and thought it felt good. Now that everything is apart, I noticed it should be replaced. I'm glad the throw out bearing was an issue. Even though the clutch felt good for the three miles I drove the car. It needs replaced. I took some pic's of everything. I'm going to have the flywheel surfaced tomorrow and the new Valeo clutch is on it's way along with the pilot bearing, throw out bearing , and crank shaft rear seal.
azruss
Re: More progress
Post by azruss »
while everything is apart, check the throwout bearing arm. they will crack at the pivot point.
azygoustoyou
Re: More progress
Thanks, I checked it out. It is good. :P
htchevyii
Patron 2022
Patron 2022
Re: More progress
Post by htchevyii »
azygoustoyou wrote:Image
That's purty !!:D
Trey
124JOE
Re: More progress
Post by 124JOE »
i want one
oh wait i have one but it DONT LOOK like that
azygoustoyou
Re: More progress
I finally got my new rear crank seal and pilot bearing in. I was installing the flywheel and realized how in the hell am I going to torque it to 105 ft. lbs. On the 1800 engines the flywheel bolts are M10 with a 12.9 class rating. I used my impact gun to tighten them. Of course I broke one and probably weakened the others. I bought new ones just to be sure.
I'm going to make an adapter to hold the flywheel to the block so I can go back to the torque wrench. :roll:
TulsaSpider
Your car is a: 1978 Spyder 124 2L
Re: More progress
Post by TulsaSpider »
I used a ratcheting strap and strapped the flywheel to a table and cranked it down. I would love to get my valve covers looking like that!
azygoustoyou
Re: More progress
TulsaSpider wrote:I used a ratcheting strap and strapped the flywheel to a table and cranked it down. I would love to get my valve covers looking like that!
Thanks for the tip.
I sent these to SoCal Mark. He had them ceramic coated at a shop he uses. Pretty cheap. :P
azygoustoyou
Re: More progress
I have an IAP book 75-on and it stated to torque the flywheel bolts to 105 ft lbs. That must be for a 2000 eng with M12 bolts. But the book doesn't state that. I found out the torque rating for M10 bolts is only 62 ft lbs. Just wanted to let you all know so you don't do the same mistake breaking the bolt. If I were to break a bolt though, I'd want it to be the flywheel bolt. It was so easy to get out by taking off the flywheel. At first when I heard it break, I thought I was screwed. Got lucky this time. :roll:
azygoustoyou
Re: More progress
I tried to find new dust covers but couldn't so I decided to fix the ones I have.
azygoustoyou
Re: More progress
I got the bolts for the flywheel today. I took a piece of steel and drilled two holes in it to fit on the pins on the flywheel. I then torqued the bolts to 62 ft lbs with ease. :P
azygoustoyou
Re: More progress
:P
boogiedude
Your car is a: 1978 spider 1800
Re: More progress
Post by boogiedude »
Brady, have you ever considered making a true short shift kit for this car?
azygoustoyou
Re: More progress
What do you mean? I have a short shifter but I think I like the long one better. I don't think your talking about that though.
:roll:
Locked
