Can engine block be fixed?
ventura ace
Re: Can engine block be fixed?
Post by ventura ace »
". . .and modification to the replacement part done. End was threaded and a cap (bolt) "
I can't tell from the picture, but I need to ask about the cap bolt that you used to plug the aux shaft. Did you make sure that it does not plug the oil path from the hole down the center of the shaft to the cross hole at the rear bearing suface? You need to have a clear path for oil to go from the front bearing, down the length of the shaft, and out the cross-hole in the rear bearing, or else the rear bearing will not be lubricated.
Alvon
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Post by wachuko »
ventura ace wrote: ". . .and modification to the replacement part done. End was threaded and a cap (bolt) "
I can't tell from the picture, but I need to ask about the cap bolt that you used to plug the aux shaft. Did you make sure that it does not plug the oil path from the hole down the center of the shaft to the cross hole at the rear bearing surface? You need to have a clear path for oil to go from the front bearing, down the length of the shaft, and out the cross-hole in the rear bearing, or else the rear bearing will not be lubricated.
Alvon
Alvon,
After it was done I filled the shaft via the front hole until oil came out on the other end. So it should be fine. The bolt went in about 3/8".
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
