Custom Pininfarina Emblem
Re: Custom Pininfarina Emblem
My wish list is for a FIAT logo in thin alum that can be bolted or maybe riveted to the valve covers. I think there is an abarth version that already exists.
http://www.abarth-gmr.be/new/parts.php?dzial=all
I can send you the logo if that helps
Were you talking about this one, specifically, but with the Fiat logo?
Yes. But with a bit more style...i have a few ideas. Is this type of thing do-able?
Perhaps reading Fiat 124? Or even just Fiat like the second example here...just larger than this one?
Doable? Certainly. However something like that would take so much time running on the machine that it's unlikely to be worth the investment. With a design like the one I made, it's simply a matter of taking a rectangular piece and cutting a design into it. With yours, everything that's NOT part of the design has to be removed, which opens a whole can of worms. The simplest actions, down to clamping the piece, become much more complex and time consuming once that much material is removed.
However, thinking a little more outside the box, making a mold and then casting the parts would be ideal for yours. I personally have no experience in that area but I don't see why it couldn't be done with a little practice.
Hope that made as much sense in words as it did in my head.
Indeed it does. As a woodworker i can visualize the milling process...
Not directly Fiat related, but I made a new hatch emblem for my 280ZX track car, hinting at what lurks under the hood (the white support material dissolves away, leaving only what's in blue). I don't see any reason the valve cover emblems couldn't be done the same way.
I'm in for 2 sets. Should I work on a logo?
Personally Id rather have just Fiat maybe with a "stripe" in front and behind but if others like the 124 i'm OK with it. For the valve cover logo I mean. this might be really cool in a small size for the glovebox door or something...
thanks!
thanks!
Austenp405 wrote:Were you talking about this one, specifically, but with the Fiat logo?
I actually own the top cover... The Abarth was pretty hand made
R
sorry I realized I personally suggested "fiat 124". Im in for the one you've displayed. Ramzi, how do you adhere the Abarth and the 124 to the covers?
It'd take no time to drop the 124 and see what it looks like. I'll try it when I get in to work again on Monday.
As far as attaching them, I'm not sure how the originals were done but I was thinking a thorough cleaning then a dab of hi-temp epoxy. I could also add holes for bolts or rivets.
Here's what it would look like with just the Fiat part. I added some holes so it could be riveted or bolted onto the covers if that's your thing.
I like it with or without the 124. My only small complaint is the font looks to bubbly. At first i thought maybe sharp inside corners wouldn't work but looking back at your Z version proves otherwise. If it helps i could search for a font that might look a bit more "vintage" in feel.
What kind of file do you need? Sorry to be so picky
