High performance motor build.
Re: High performance motor build.
the problem with milling them is that the dome is hollow, so you can't take enough off.
I didn't have a mic to check the thickness,but my best guess using the digit method,might be around 10-15 mm thick was about it.(if that) When shaving the top I can see the shoulder ,(edges) area getting thinner. I don't suppose that would be good eh... If I have time tomorrow,my neighbour has a set of measuring devices that should work.So Cal Mark wrote:the problem with milling them is that the dome is hollow, so you can't take enough off.
My car is 1980 does not have the Fuel Injection on it any longer did the have to change the head to remove the fuel injection?
I didn't have a mic to check the thickness,but my best guess using the digit method,might be around 10-15 mm thick was about it.(if that) When shaving the top I can see the shoulder ,(edges) area getting thinner. I don't suppose that would be good eh... If I have time tomorrow,my neighbour has a set of measuring devices that should work.[/quote]
The Persan pistons are 8mm thick in the center of the dome.
What ever happened to this engine rebuilt,
Did you follow thru? And and,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
maybe they are hiding from you?fiat218 wrote:What ever happened to this engine rebuilt,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1980 Spyder 2000
- Contact:
Sure wish I head for my motor.......
**sniffle**
**sniffle**
Matthew Basaraba
1980 Fiat Spider 2000
- v6spider
All that work and money to build up an engine that won't make even 200hp.. cheaper to swap out the engine for one that will make the power.
Again just my two bits.
Rob
Rob
http://www.v6spider.com
I got themnarfire wrote:Ok have a pic of these Persan supposed 84.4mm pistons
Measured the skirt
Looks like 8mm domed pistons. I was going to use them in another engine build,but not in the works at the moment. perhaps later.
So these domed pistons are not the best for street use? I wanted more power but still drivable in traffic in a carb'd engine and after market cams ect...
Sorry for perhaps crowding your thred eh..
Chris
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
correction jim, i have them
even though they are yours
son has 78 spider
son has 78 spider
What head do u needbasarabam wrote:Sure wish I head for my motor.......![]()
**sniffle**
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Glad they made it down there
- Contact:
I have a head coming, was just messing with one of the posters.fiat218 wrote:What head do u needbasarabam wrote:Sure wish I head for my motor.......![]()
**sniffle**
Matthew Basaraba
Lol oh damn it, lolBEEK wrote:correction jim, i have themeven though they are yours
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
