Page 3 of 3
Re: trunk floorboard template
Posted: Sun May 13, 2012 10:17 am
by grittracing
if your trunk carpet is in poor shape you can dress it up by sewing material to it rather inexpensive. but i would suggest quilting it. that way both pieces stay together
Posted: Sun May 13, 2012 1:52 pm
by 4uall
I can hear the bagpipes from hear. Nice tartan
Posted: Sun May 13, 2012 2:45 pm
by blurple124
Can this be done with a 4' X 4' piece? I'm guessing not. What has been the preferred thickness? mine came with 1/4" boards.
Posted: Sun May 13, 2012 4:49 pm
by grittracing
This is a tartan. I orderd it because it had all my cars colors. It can be done to any trunk carpet. No boards in this. Just carpet
Posted: Mon May 14, 2012 6:50 am
by 124cso
blurple124 wrote:Can this be done with a 4' X 4' piece? I'm guessing not. What has been the preferred thickness? mine came with 1/4" boards.
I guess you are talking about the floor boards ? You will need a piece 40" x 30". A bit bigger would give you some leeway but if you make a cardboard template first, get that to fit o.k., you will be fine. That does not include any vertical side panels. From memory, my original floorboards were 5/32" or 4mm or so thick. I used what I could find that "Looked the part", hence the panel off a feed pallet (smooth one face, dimpled the other like the originals) but 1/8" or 3.2mm+/-. Seems to be strong enough and I glued a 5/16"+/- batten underneath to the tank panel, along the joint and across the rear (taillight) edge. They both sit on tank & spare wheel so are supported. Would only be a problem if a heavy weight and no spare in place.
It looks like there are variations in trunk carpets too. Jimmycakes' pic above shows a carpet with 2 side panels, but my 80 model (built late 79) is like the Tartan backed one above.
Posted: Fri May 18, 2012 10:22 pm
by 124cso
jimmycakes401 wrote:Mine looks like this. I also have a long thin piece with a rectangle cut in it which I think goes up against the lock wall.
FWIW, I just looked up the "Spiderpoint" cat ( from Germany) and their carpet kit looks just like jimmycakes's.
Posted: Fri May 18, 2012 10:51 pm
by jimmycakes401
Hopefully cleaner.
Posted: Mon Jun 18, 2012 7:28 am
by deftone
grittracing wrote:if your trunk carpet is in poor shape you can dress it up by sewing material to it rather inexpensive. but i would suggest quilting it. that way both pieces stay together
As a Scottish expat living in Tx.... I love what you have done with that. I may try it myself! How easy was it? Im not much of an upholsterer
Posted: Sat Jul 07, 2012 6:57 pm
by grittracing
About a yard. And i had to go to a tarden web site to find all of the colors in my car. And it was very easy I took it to a car upholstery place think I paid 35-45 and they put the black belting around the edge and guilted it.so it would last longer. Make sure to mark the side you want up/showing
Posted: Sat Jul 07, 2012 7:00 pm
by grittracing
About a yard. And i had to go to a tarden web site to find all of the colors in my car. And it was very easy I took it to a car upholstery place think I paid 35-45 and they put the black belting around the edge and guilted it.so it would last longer. Make sure to mark the side you want up/showing . I was also contacted by someone to make a templet for the trunk card board and I sorry to who ever that was. I have lost the email with address . Please contact me again if you don't have it already.I have had a lot on my plate at home in the last few months.
