Thanks, Mark.So Cal Mark wrote:one of the most common mods I see is that an owner opens the AFM and "tweaks" it to make the motor run better. That changes the adjustment of the fuel pump switch in the AFM allowing it to make contact constantly.
You really should start your own thread on this, probably will get more replies that way
Sounds like another switch to look at besides the dual relay. Can it be checked or is it "solid state" stuff? I was just going to check the AFM for a "sticky flap". "Sticky" things are not unusual with this car, since is appears not to have been registered or driven much by the PO from 1987 (when it was brought from Florida to Wisconsin) until 2009 when I bought it as a non-runner (under 80Kmi). I am just now beginning to do more Engine/fuel things myself as I learn more. Did a lot of lighting work last year.
Yes, I will start another thread after I get in to this and can better visualize what I am talking about.
