any clues? faulty something...
arana
Re: any clues? faulty something...
Post by arana »
thanks for the responses... Like pooldoctor says, I think I've pretty much eliminated every other possibility. It is definitely fuel related (the die routine is much more like running out of gas than just turning the key off) and now I think it is pretty safe to say now that it was the tank garbage. I cleaned it by repeatedly rinsing it with clean gas, which I know was not sufficient. I also know I'll never be able to find a replacement, so I have to find a shop to restore it. Like I mentioned in a previous post, anything to do with refurbishing car parts can be found in Peru. I think the die routine I had after cleaning the tank was the result of still some debris so I guess I'll have to clean the carb again. thanks again, mil gracias.
ga.spyder
Post by ga.spyder »
Sorry I am late on this.I had the samr symptoms with my carb'd 77.Mark suggested debris in the float bowl.As usual,he was right.Havent had the problem since!Buena Suerte,
Craig
Craig Nelson
Fling It Around Turns !
katsi
Post by katsi »
It seems like you have changed all the major parts but how about the fuel lines or the filter? When I first drove home my spider it did something simular. I put new fuel lines and a filter in and it cleared up that problem. Does it seem to happen when the fuel gets low? Maybe something in the tank blocking the fuel. Turning off the fuel pump would let that "Something" settle back down. How is the tank? Might be rusty? Can't hurt to put a clear filter on it to see what it's sucking up if anything. Hope you get it ironed out soon. Good luck!
MNspiderman
Post by MNspiderman »
There are plenty of guys here that have parts for sale. So Just ask.
