Okay y'all... I don't wanna get caught-up here in another one of these. "Cut the Belt off"..... I can't figure-out why you care, as long as the stipulations that I laid-out previously are met: a) we know we're replacing the belt, b) we know the cams don;t line up.
Sure. Loosen it all up to remove the belt. That's fine too. You're right, you're gonna loosen it all up eventually anyway... so why do you care if it gets cut off? Methinks this smells of a case of "this is the right way; just because I said so".
in reality, I have never cut one off... it's more of a figurative sort of "be done with it already"..... but I honestly can't see why you care so much.
Magic: I think it's funny that you use the book to point-out the "correct procedure" when it agrees with you (removing the belt), but then you say the book is wrong when it disagrees with you (slackening via two bolts).
And there may well be some "competent mechanics" out there. I've yet to find one that knows how, and cares, too.
There's way too much apathy out there. So some of us would prefer to do our own work. And some (like Oklandspider) have a learning curve that is in a different place than yours, or mine. Don't discourage him though. Part of the fun of owning an enthusiast car like this is the tinkering. Let us all learn as we go? And let's not get so caught-up in the "only qualified mechanics / engineers should be mechanic-ing / engineering on these cars" debate?
(I just LOVE to stir the pot)
That being said: I'm confident I'm as smart as the next guy (you, Magic, for instance
), and I don't think he's dealing with a fuel supply issue here at all. You keep saying it's too vague to tell... but you keep steering him back to the same place.... even after all his checks (that you suggested, remember) came back 'passing'. Now, I'm by no means anywhere near "certain".... because as you say, there is NOT enough information. So I'm all about helping him chase down that road, or any other that seems to fit the symptoms.
It's too bad he's not "SaltLake-Spider", instead of "Okland spider".... 'cuz I could be more help then!
