No RR Turn Signal w/Headlights On
FordPrefect
Your car is a: 1977 Fiat Spider 124
Re: No RR Turn Signal w/Headlights On
Post by FordPrefect »
Foster48x wrote:Good thing I'm not an electrician by trade... or with the Fiat maybe that's not a good thing that I'm not an electrician... oh well, lesson learned.
Rick
It's ok, I don't think the original guy that wired these Spiders was an electrician either. :)
smfinley
Post by smfinley »
One other thing I have done is change the thermal flasher for the turn signals to an electronic flasher. My turn signals would flash very slow when I stepped on the brake. Another thing you can check is the voltage at the lightbulb. I found when I had the brake and turn on the voltage dropped to about 9 volts, after adding a ground the voltage raised to over 10 volts, which made a difference in brightness and flashing speed (before installing the elctronic flasher which is a fixed time).
