Who is going to FFO ??
Re: Who is going to FFO ??
All this talk about FFO has me bummed.
My vacation was used for the drive up to Oregon and Washington. But I sure wish I could be there with you all.
Don't forget your cameras.
we need a West Coast Freak Out to end all of this envy
Hear, hear! (Or is it: Here, here!?)
- Your car is a: 1982 Fiat Spider 2000 Turbo
Craig,
you are correct. I will be there as well. We are arriving Friday afternoon and leaving Sunday. My wife and I are bringing the kids this year, and as a result are towing the Fiat (no room for whole family and all of our stuff in the Fiat). So after all of the grief I gave you for towing your car last year, now I am doing the same
. But at least I am bringing it! So I will have something else to give you a hard time about this year
John
John
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
That should work, before the afternoon drive, which I imagine will be a little later.ga.spyder wrote:How about 1:00 on Sat at the FLU area of the vendor tents?
Craig
- sjmst
I will be there! Bringing the Fiat. Been to may FFO's but have not brought my car since 1987.
Hoping also to get someone to diagnose my rough idle problem. Stalls out when cold. When warm does not stall, but still rough idle. Runs GREAT once underway.
Ideas? I went through the Fi manual and still stumped, so if any Fiat docs could listed to it and advise, I'd be grateful!
-Sam
Fiat Club America Long Island Chapter Contact
1981 Fiat Spider 2000 (original owner)
1982 Fiat X1/9
2017 Alfa Romeo Giulia
2018 Alfa Stelvio
1982 Fiat X1/9
2018 Alfa Stelvio
- launieg
SJMST, now that's how I would like my '81 to look!
Everything looks just right - clean and beautiful. I also love that color (but mine is turning green -literally).
Since I'm already posting, I might as well put in my two cents worth on your problem. Have you have tested the auxiliary air regulator and the temperature sensor in the coolant T above the radiator? It would seem to me that it is likely to be one of those two items. You can put an ohmeter on the temp sensor to test it, info at this thread:
http://www.fiatspider.com/f08/viewtopic ... tor#p47372
Or just swap it out for another, and see if the situation improves.
The process to test the AAR is also described in Brad Artigue's FI guide. Very easily you can test it for the idle condition. Someone else might correct me on this. You start the car from cold, immediately pinch off or otherwise block off the air hose going to the AAR or from the AAR to the manifold and there should be a difference to your idle (worse). If no change in the idle, then the AAR is probably not working (it is remaining shut at all times). Those hoses are quite brittle on my machine, so you might not be able to pinch them. You can also easily test it for electrical input (as per Artigue's guide).
Have fun at FFO. Wish I could be there.
Launie
'81 Spider Rolling Restoration
if it idles rough, but runs good at speed, expect a vacuum leak. I'd check the injector seals. First, isolate which cylinder is misfiring.
- sjmst
Thanks for the compliments, guys and the advice!
-Sam
1982 Fiat X1/9
2018 Alfa Stelvio
1982 Fiat X1/9
2018 Alfa Stelvio
- ga.spyder
See you there ,Sam.It seems to me you brought a awfully good looking car to FFO last year?
My 82 has developed a little rough idle very similar to what you describe,so I will be eager to hear the diagnosis.
Craig
ps,,,John K. ,I would be disappointed if there wasnt something for you to give me grief about!
Craig
Craig Nelson
Fling It Around Turns !
I to have the dreaded rough/too low idle, but only when cold. I purchased a new coolant sensor months ago, but have not yet installed. I tested the AAR by pinching off the hose when cold, and it didn't seem to make any difference.
John
'12 Abarth 500
'12 Abarth 500
I'll meet you at the tent at 1:00, Craig. I'll be the hot Mama with the big red Suburban and 4 kids.
- ga.spyder
Wont you be there Friday? I will be getting there at 4-5 pm on Thurs.Call me...I love getting calls from hot mama's in red Suburbans
4 kids,man I was at your house couple weeks ago and you only had 2!!! You really have been busy.
Craig
Craig
Craig Nelson
I'll be there Thursday afternoon too. I'm hoping to have a signal on my cell phone by the time I get off the islands and I'll keep in touch enroute.
