Okay, I replaced the AAR and no luck the problem still exists. Could this be a temp. sensor issue or possibly an exhaust problem? Any thoughts would be much appreciated.
Thanks, Mark
'81 Turbo Spider won't idle when cold
- kustom
Re: '81 Turbo Spider won't idle when cold
Our cars should meet. My 81 idles perfectly when cold, but likes to creep up to 1500 rpm when warm, maybe they can figure it out themselves.
Phill
1981 Spider
2014 Ram 1500 Eco Diesel
2007 Acura TL
1981 Spider
2007 Acura TL
- Your car is a: 1982 Fiat Spider 2000 Turbo
Still sounds like an air leak to me. If you haven't already done this, I use a propane torch to check for air leaks (others may have better methods to share). Once you can get your car to idle on its own, turn on your propane torch, but DO NOT light it. Move the torch tip around the various parts of the intake system (hoses, plenum, manifold, etc.). If/when the idle increases, you have found your leak.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
