Front Sway Bar Question
- Your car is a: 1971 Fiat Spider 1600
Re: Front Sway Bar Question
Thanks to Bryan for the detailed response on the sway bar. If it's unnecessary for gentle driving, then I suppose the one bolt may be enough for the gentle cruises planned.
I really want to drive this car, but also I really don't want more of it to break away. I think I just might painfully wait the weekend out and get it into the shop on Tuesday
Dave-O Supreme-O
1979 Fiat Spider 2000 "Fiona"
I can report that my welding skills have greatly improved since getting my 1978 Spider. The little 110 volt flux wire feed units from Harbor Freight that go on sale for less than $100 work very well "IF" you use the Italian INE or the Harbor Freight Vulcan (also from Italy) wire.18Fiatsandcounting wrote:Regarding a snapped off stud, the best solution (although not necessarily the easiest) is to take it to a shop that can drill out the broken stud and weld a new one in place. If you have a welder, you can do this at home...
Be sure to treat the area with Ospho to keep the rust at bay and use a good weldable cold galvanized primer.
