SteinOnkel wrote:Hey guys,
I tore off a wire on the alternator the other day. It was purple, so I soldered it to the other purple end on the engine bay harness.
Couple questions.
1. Was everything working correctly before the wire was tore off?
2 When you said Tore off, did you mean the wire broke in two, and you just reconnected it at the break point?
If the answer is Yes, and No correspondingly, could you have reconnected the wire to something entirely different? Back to a previous post's comment about, purple, vs purple and black stripe wires.
Soldering wouldn't damage anything unless you melted other connections from excessive heat or extra solder or the iron shorted across terminals wit power on them. (of course disconnecting the battery whenever working around the alternator is vital for fire and safety reasons if nothing else..)
