A new member in Western Canada
Re: A new member in Western Canada
by all means remove the emission equipment, especially the air pump if its' driven by the exhaust cam.
I spent most of the day trying to clean 30+ years of dirt from the car. I removed the seats and centre console, took out the carpets and padding and tried to take some of that tar crap off the inner floor pans. I then gave the car a good vaccuuming to try and get some of the dirt out. The hole in the driver's rear floor pan is pretty much directly under the outside seat rail. Hopefully a patch will suffice. I looked at the inner rocker area and it is still solid. I found a bunch of broken glass in the area while vaccuuming, so I assume the window was broken at some point, hence the rust. I took some photos and posted them here. http://s285.photobucket.com/albums/ll60 ... %20Spider/
I adjusted the float on the carb and it made the car run much better. I think it still needs to be adjusted for mixture, but that will come later. At least I got to drive it around the block.
- Your car is a: 1982 Fiat Spider 2000 Turbo
It actually looks like a really solid car. The body is remarkably clean, looks like it only needs minimal body work, and the top looks great. I think you have a winner there.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
Thanks. Other than being incredibly dirty, the car is pretty solid. It isn't rust-free but that is tough to find with any 30+ year old car. My plan is to work on the body over the winter and get it ready to paint. I think I will lose the bumpers and install one of those turn-signal kits in place. Less weight, cleaner lines. Other than that, I plan to keep the modifications to a minimum. I want to get it back on the road and worry about tinkering during our long, cold winters.
