bizarre ignition problem
Re: bizarre ignition problem
it's hard to believe the fan causes the voltage to drop that much. It could be that you have some poor connections that are susceptible to a voltage drop due to high resistance. I don't believe I've ever seen a ballast resistor that drops the voltage as much as yours' does
