1984 Pininfarina
pope
Re: 1984 Pininfarina
Post by pope »
There should be only one [...] at the front and one at the back. You have two. Just delete the second one at the front and the back and you are good to go.
Leesfer
Post by Leesfer »
To make life even easier, photobucket has the html code already made for you under each picture you upload... just copy and paste and you are good to go!
correction: you want to copy and paste the IMG one.. underneath the pictures on photobucket there is four or so boxes, just copy paste the bottom one
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
Joe, have you found the two fuse holders under the dash yet? There are two red plastic holders, about 2-1/2" long. They should be up amongst the wires behind the fuse panel. They are in-line type and have spade type connectors on both ends. You will unscrew them to get to the fuse. One of mine was real hard to find, the PO had put it laying on top of the bracket for the steering column and it couldn't be seen, had to feel around for it because I knew it was up there somewhere.
Happy hunting.
Ron Luxmore
rlux2n2@gmail.com
mbouse
Post by mbouse »
Leesfer wrote:To make life even easier, photobucket has the html code already made for you under each picture you upload... just copy and paste and you are good to go!
let's make things even easier. Ship me the car, and I will take pictures of it and post them for everyone to see.... :shock:
Forestpark
Post by Forestpark »
Image [/img]
Forestpark
Image Image Image Image [/img]
Forestpark
Image [/img]
Okay! Thanks for all the help, fellas. I found the fuse holders, Thank you. I'm looking (down the road) for a A/C mounting bracket. If you hear of one would you pass the info along to me? I've got a pix stored on my computer. 1983,84,and 85 should work. I don't know about previous years. Anyway, thanks for all the help. Now I won't have to ship the car to Mike for the photo shoot. Doesn't look like this last pix made the transfer. Oh, well. Enough posted to see the mess. Well maybe it did make it. Later all--Joe
to get the pic to display, make sure there is only one (img) before and after the address
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
What a project! But I don't see much rust there, that's good. It will turn out great. Thanks for the pictures.
Ron Luxmore
rlux2n2@gmail.com
