I use Ron's method; a tube with a funnel at the end that runs down through the engine compartment to the tranny and into the fill hole. Since I don't have a willing assistant (ie. a son at home) I pour in the estimated amount needed, and check for a small trickle of oil streaming from the hole to indictae its full.
AFields
1980 FI Spider 2000
Charlotte
how do I fill tranny gear oil??
- ga.spyder
Re: how do I fill tranny gear oil??
I bought a cheap siphon pump from Harbor Freight(I'm sorry Mike and I promise to never go in there again).One end in the bottle ,the other in the top of the tranny.VOILA! Unassisted ,mess-free tranny oil change.Works on rear end dope also.
Craig
Craig
Craig Nelson
Fling It Around Turns !
I've thought about doing it that way Craig, but I always assumed the lube would be too thick to use a siphon or a plastic pump. Yours worked OK huh?
- ga.spyder
Ron ,it worked just fine .I bought the pump that looks like a small basketball pump ,it was around $6.00. I wasnt sure if it would work w/ thick lube either but no problem.
Craig
Craig
Craig Nelson
just don't try it on a real cold day unless you warm the oil first
OK! This is good to know, because some day my son will move out. Maybe.
or, he'll seize the house and have you commited to a home for the aged
Tipping your car on it's side sounds funny, but...
I was talking with a guy that's retoring a classic Mini. I asked if he was using a rotisserie, and he said "No, I just use a matress!". By himself, he just rolls the Mini body on it's side, onto a mattress, so he can refinish the bottom of the car.
