Alison's twisted header
Anything goes (within forum guidelines of course)
MIGHTY 8
Your car is a: 1980 Spider
Re: Alison's twisted header
Post by MIGHTY 8 »
fiat218 wrote:Where does the coupler go
If you purchased it from Mark's, I would recommend you ask there to get the most accurate response.
fiat218
Post by fiat218 »
Yes I have one being made. I'm sure I will get what I need ,thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
the flex coupler should go between the collector and the front mount. We include very detailed instructions with the exhaust system explaining how the system should be mounted (with the included hardware). Unfortunately, many buyers prefer to build their own system. This can lead to a system that completely contradicts what we sell. We've seen systems with every joint welded solid with solid mounts and all of the weight hanging on the header and the header wrapped. An installation with these sorts of problems virtually guarantees that the header will be damaged.
We also include in the instructions detailed information about tuning and the temperatures that the header and coating can withstand. It's critical to have the engine properly tuned or the header can be overheated and it will fail if it's melted down. I've had cars come in that were far enough out-of-tune that the header temps hit 1500f under heavy load. After tuning, the exhaust temps were in the 600 range under the same conditions. If you don't have the ability to measure air/fuel ratios and exhaust temps, then you need a professional tuner
westy64
Post by westy64 »
Redline wrote:This twin air filters are nice. Where are they from?
they look like standard K&N or EMPI filters for IDF.
very popular and available in all aircooled VW shops.
spiderrey
Post by spiderrey »
They are empi,s, I cut one up but still have one. They come in different heights. Might go that route again, or might make a similar looking set up using a 240 z air cleaner.
sawmkw
Your car is a: 1982 Pininfarina
Post by sawmkw »
So Cal Mark wrote:the flex coupler should go between the collector and the front mount. We include very detailed instructions with the exhaust system explaining how the system should be mounted (with the included hardware). Unfortunately, many buyers prefer to build their own system.
Mark,
As you can see from the pictures, I have your exhaust system; have it installed using your mounts, connectors and no welding. What I do not have is a flex joint which I suspect I need otherwise why would you have added it to the current system? How do I get that flex joint and add that to my system?
Scott
82 Spider Green
82 Spider Plum
82 Safari Ivory
80 Spider Driver Red
77 Spider Red
Hopewell NJ USA
flex joints are available from any muffler shop or I can supply one. It should be installed in front of the first exhaust system mount
sawmkw
Post by sawmkw »
So how is the flex joint merged into an existing down pipe? Sounds like cutting, fabricating and possibly welding which would make what I have look terrible.
Scott
82 Spider Green
82 Spider Plum
82 Safari Ivory
77 Spider Red
Hopewell NJ USA
the pipe would have to be cut and the flex joint either welded or clamped. We started including these because we found many installers mounting the system with solid mounts, not allowing any flex in the system
fiat218
Post by fiat218 »
I assume I got one
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
yep, we've been making the systems with a flex joint for over a year
TX82FIAT
Post by TX82FIAT »
The bottom of that car looks like it just came off the assembly line. Very clean. No oil or road dirt anywhere.... Wow... is that a frame up restore?
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
I have seen the rest of the car. Amazing !!!
Maybe the owner would post a few engine photos 8) .
Exit98
Post by Exit98 »
The car is stunning.
It isn't done yet but the motor is in and running.
Mostly interior left now.
Scott is a perfectionist.
