78 1.8L Engine Rebuild
djape1977
Your car is a: 1970 fiat 124bc
Re: 78 1.8L Engine Rebuild
Post by djape1977 »
sandpaper?
White78
Post by White78 »
djape1977 wrote:sandpaper?
I was using a flapper wheel and gave up once I hit the metal mesh. I set the oil filter manifold in a shallow gasoline bath and left it over night. The next day came right off.
White78
Post by White78 »
Here is a couple more progress pictures.
Cylinder Head Painted
Performance Cams from Mark at Allison's Automotive
I flipped over the head to take a look at the valves and noted some pitting on the #1 cylinder. None of the other cylinders have this. Is this something to be worried about. The automotive shop that did the machining and assembly of the head didnt mention it all. What do you guys think?
Progress on the block
Regarding the timing belt, is it possible to get it on with out removing the crank pulley?
vandor
Post by vandor »
Yes, the timing belt can be installed with the crank pulley in place. On 2 liter engines the timing pointer has to be removed.
dry cams! Make sure you coat the lobes with the assembly paste that came with the cams!
White78
Post by White78 »
So Cal Mark wrote:dry cams! Make sure you coat the lobes with the assembly paste that came with the cams!
Ok will do. Thanks for the heads up.
White78
Post by White78 »
vandor wrote:Yes, the timing belt can be installed with the crank pulley in place. On 2 liter engines the timing pointer has to be removed.
It seems to be very tight between the pulley, crank sprocket and the front seal housing. I am worried about damaging the belt. At this point it is easy enough tp remove the pulley, but seems like a very akward job for the future.
djape1977
Post by djape1977 »
nothing to worry about
White78
Post by White78 »
Almost there!!!
Need to put on the engine mounts, carb, coolant hoses and the flywheel.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
what was the reason for the center part of the timing cover to be cut out?
75 spider
son has 78 spider
djape1977
Post by djape1977 »
so he can remove it at some point in future without removing a water outlet
White78
Post by White78 »
Yep seems silly to have to drain coolant to change out the timing belt. Not sure if I will ever need too, but what the heck I am going to be ready for it.
vandor
Post by vandor »
You have to undo the Tee to remove the belt :-) As the belt goes around it.
White78
Post by White78 »
I have attempted to install the engine. I am really struggling with getting the transmission shaft to engage the clutch and/or pilot bearing. I imagined that with the alignment fairly close the install would be pretty straight forward. Am I missing something? Any tips or tricks that may help? Thanks!
djape1977
Post by djape1977 »
needs to be perfectly aligned. fairly close ain't close enough.
