Squeaky Brakes & Knocking RESOLVED
Re: Squeaky Brakes & Knocking
Post by RRoller123 »
That is correct. Normal threads on driver's side, reverse on passenger's side.
4uall
Post by 4uall »
Thanks Chris, going soon to check it all out :roll:
4uall
Post by 4uall »
narfire wrote:Jay. I recently replaced the hub on the front passenger side. To undo the nut I turned the wrench clockwise.
Chris
Chris, I love you, I hate you :x I love you for being right, I hate you for letting me know I had it on the wrong side :wink: Guess who's doing a swap tonight?
narfire
Post by narfire »
No worries Jay.... I have a brake booster to change... and that means the under dash contortions and clutch cable cable disconect at the tranny..and a bit of knuckle rash..
4uall
Post by 4uall »
arrrrrgggggggghhhhh I am missing a lug bolt :shock: Anyone have/ know what size is required for these wheel :?
Exit98
Post by Exit98 »
Jay,
LOL, you are using the lug nut tool from the Fiat tool box.
I didn't know it actually worked. Maybe you might consider picking up one of these at Sears:
kilrwail
Post by kilrwail »
Jay - Where did you put it??!! It was on there when you started! Chuck may have one - let me know if you don't have his contact info.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
4uall
Post by 4uall »
@Doug I used it to make sure it worked, once. I love my impact driver.
@Peter I lost it somewhere between Milano's and Tuesday :shock: It was missing before I even jacked the car :x I will send Chuck an email and cross my fingers. I also sent an email to Ottawa Fasteners. Worst case I will buy some :roll: Anyone know the size?
narfire
Post by narfire »
19 mm head 12 X 1.5 thread. I use a breaker bar when the car is on the ground to loosen and then when in the air, the battery impact drivers will undo the rest of the way.
Just remember when putting the tires back on and the car is on the ground to tighten with a torque wrench or the breaker bar and don't count on the battery impact to be tight enough. :oops:
I regularly use a torque wrench on mine, and I found that after I had refurbished the wheels last year, which included sandblasting and painting, that they needed to be checked about every week as I was finding them a little below torque each time, not quite loose, but if I hadn't checked them, they WOULD have come loose and eventually probably fallen out. It was clearly a result of the fresh paint on the contact areas of the wheel/bolt. I now check them with the TW about every month or so and after found that the first month or so there was no loosening whatesover. (I drive maybe 100 miles per month). In the future I will mask or remove any paint from the bolt contact areas on the wheels! :roll: :shock:
4uall
Post by 4uall »
I was very lucky to have a friend (Chuck) locally who has some for me. looking to pick them up today or tomorrow. Long weekend so would love to be driving safely 8)
kilrwail
Post by kilrwail »
Good!
Peter Brownhill
4uall
Re: Squeaky Brakes & Knocking RESOLVED
Post by 4uall »
Did the swapping of the steering knuckles. Was all excited to take her for a test drive and as I pulled out, there it was :shock: the f'kn knocking again :x Back in she went. Took it all apart again to find that it was the brake rotor :o :o :o :o Replaced and voila, no more noise :) Put on the lug nuts, torqued to 62lbs and took Fiona for the best test drive ever. She rides soooooooooooo smooth now. :mrgreen:
narfire
Post by narfire »
Well done Jay. I think I'll have a glass of wine or a gin and tonic in celebration... :D decisions decisions...
courtenay
Post by courtenay »
Why not a gin and tonic then a glass of wine...or two. Makes the decision process a hell of a lot easier!!
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
