Thanks azruss. I found a connector and boot at Auto Ricambi. Hopefully, that will take care of my issue.
Yes. Good point about the staggered splice.
Loosing power but not stalling/Has now changed to won't idle
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
Re: Loosing power but not stalling
Giulio/Charlotte
- giuliot60
I just got my new CTS connector today. Hopefully that takes care of my issue. It's been a week and I miss driving her.
Giulio/Charlotte
- giuliot60
Re: Loosing power but not stalling/Has now changed to won't idle
So. I got the connector yesterday, and installed it today. It definitely needed replacing, but although she starts right up, she quickly starts to run rough and eventually stalls, but will start right up. I was thinking that since the fuel mixture wasn't correct, and has been smelling rich, it may have thrown off. So I pulled my plugs and they are BLACK.
Are my plugs shot, and do you think replacing them will get her idling correctly, or could it be something else?
Any thought would be greatly appreciated.
Thanks!
Thanks!
Giulio/Charlotte
- FiatMac
Have you checked the temperature sensor itself? When the engine is cold as measured by the sensor, the ECU adds extra fueling (like a choke on a carb). If it is always showing high resistance, the engine will start and run OK cold but will run very rich at temperature. I think the resistance value should be something like 9000 to 12000 ohms cold and 300 ohms hot.giuliot60 wrote: I was thinking that since the fuel mixture wasn't correct, and has been smelling rich........ pulled my plugs and they are BLACK.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
83 parts car
pull the vacuum hose from the pressure regulator to check for signs of leakage
- giuliot60
I will try your suggestions Stan & Mark.
Thanks.
Thanks.
Giulio/Charlotte
