(Edit) Help! Can't get it to start (Video big pop at carb)
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: (Edit) Help! Can't get it to start (Video big pop at carb)
Post by RoyBatty »
Now that it's running, before you touch any carburetor adjustments.
Put a timing light on it and set your ignition timing.
Then once that is set, go about tweaking the carburetor as required.
jordi
Post by jordi »
RoyBatty wrote:Now that it's running, before you touch any carburetor adjustments.
It sounds as you need to rule out a bad intake valve with a compression test otherwise your going to be frustrated since it's acting like it has a vacuum leak which you can check via hooking up a vacuum gauge to see if you are in good range (18-22psi i believe)
