POR15
htchevyii
Patron 2022
Patron 2022
Re: POR15
Post by htchevyii »
POR15 works OK if you follow the directions exactly. It sticks best to rust, sandblasted metal or etched metal. What I don't like it that it's so hard it can't really be sanded. I have been using Masterseries, it's the same idea, "moisture cured urethane" but seems to stick better and can be scuffed and painted over far easier.
http://www.masterseriesct.com/
Trey
4uall
Re: POR15
Post by 4uall »
so here we go
seats and floor boards before phase 2 next week ( I hope) :mrgreen:
Seats before makeover by itzebtze, on Flickr
Floor before cleaning & POR15 by itzebtze, on Flickr
seat after prep & ready applied by itzebtze, on Flickr
Passenger side after Marine Clean applied by itzebtze, on Flickr
4uall
Re: POR15
Post by 4uall »
FINALLY!
POR15 applied by itzebtze, on Flickr
Seats POR15 by itzebtze, on Flickr
Fiberglassed the surprise hole then POR15 by itzebtze, on Flickr
Seems to be taking forever to dry
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Re: POR15
Post by dmwhiteoak »
Jay, How hard is it gonna be to get those seats back together? I need to remove my bottom piece and do some welding . I have had the seat out several times for one reason or another but just didn't want tear something apart I could not put back.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
4uall
Re: POR15
Post by 4uall »
Hey Dennis
The front on the seat just pulled up in the front. The back has a long thin piece of metal/plastic? that clips onto the back metal base lip. Hope that made sense.
IMG_0683 by itzebtze, on Flickr
IMG_0684 by itzebtze, on Flickr
124JOE
Re: POR15
Post by 124JOE »
man that looks good
keep up the great work
thanks for the pics
papadopalas
Re: POR15
Post by papadopalas »
I'm in the process of doing the same to my floor. Just a few questions. Did you do anything under the floor, like scrape off the pealing undercoating, grind any rust and reapply undercoat. Also can you give me some detail about the fiberglass. I have several small, rust holes and would like to do the same. Just not quite sure the "best" way. From what I've seen, the 3 step POR 15 requires rinsing off the first two steps, that doesn't sound so easy working on the floor. Scared the water will get into places I can't dry, causing more rust. Any advice would be a big help.
baltobernie
Re: POR15
Post by baltobernie »
Fiberglass + POR-15 tech tip, from the DC Fiats website:
http://dcfiats.org/tech/POR-15-2.pdf
4uall
Re: POR15
Post by 4uall »
Ditto :wink:
