Project creep... AGAIN!
maytag
Re: Project creep... AGAIN!
Post by maytag »
Oreilley's has started carrying a "ceramic" type paint (that might just be marketing, not chemical :roll: ) for calipers.
http://www.oreillyauto.com/site/c/detai ... iper+paint
this is my first go with it, so we'll see how it turns-out.
manoa matt
Post by manoa matt »
The stock steel 5mm spacers are 1/2 pound each. You added another pound to unsprung weight, consider getting some alloy spacers made. How do you screw in the wheel studs without an allen drive hole? And what are the wires aroud the caliper brackets near the sliding wedges?
maytag
Post by maytag »
manoa matt
Constructive criticism, and two honest questions that I now have the answers for, thanks.
131
Post by 131 »
The clips in the photo aren't installed correctly, both ends go in the hole in the slide, not one in one out.
Mick.
manoa matt
There are two types of caliper sliding wedge retainer clips. Original clips were an Omega shape and both ends go in the hole, aftermarket "K" type clips like the ones shown are installed correctly as shown.
maytag
Post by maytag »
131
Post by 131 »
maytag wrote:shouldn't you be using a semicolon after "correctly", instead of a comma?
Possibly, but I've never lost a brake slide when the clips were installed correctly!
maytag
Post by maytag »
131
Post by 131 »
maytag wrote:your implication, then, is that you think a safety-wired clip, installed as you see above, is "less safe" than what you "think" is correct?
huh.
ok.
No, I worked on military helicopters for 9 years, I'm all for lock wiring, when required. I worked in a Fiat workshop servicing these cars when they were new, so unless the bloke on the assembly line was installing them incorrectly, I "assume" I'm correct.
Mick.
maytag
Post by maytag »
maytag
Post by maytag »
wait.... "131" from Australia.... and you were a fiat tech in the early days..... is this Steve C.? 'cuz if so, you just explained a LOT of things.
engineerted
Your car is a: 1974 124 spider
Post by engineerted »
Hold On Big Fella!! No need to get Pissy here. I thought the same thing about the clips, as I have only used the Omega style clips. I don't see that "131" was slamming you. I know you are sensitive to what happen with Steve C. in the past.
Someone really needs to come up with a sarcasm font.
Ted
4uall
Post by 4uall »
kumbaya my lord kumbaya ohhhhhhhhh lord kumbaya :lol:
Maytag, much respect :wink:
Post by RRoller123 »
My Pastor wife tells me that "Kumbaya" is an African word/term that translated means "come by here, Lord". Gives me new respect for it. Terrible song though... {:^)
