vandor wrote:I love 1608s, but the US version only had 8.5:1 CR, not 9.8:1.manoa matt wrote:The 1608's are good engines. The bore is "square" 80mm diameter by 80mm stroke. They came stock with 9.8:1 CR but you will need a 1608 or 1438 head to top it off.
Also somebody mentioned 110 Hp. That was the Euro version with twin IDF Webers. The US model was rate at 104 gross HP, or 94 net Hp. Still not bad from a 100 cu.in. engine!
Is this true about the compressin ratios? I thought the compression ratio was the same for Europe and North America. Can anyone verify this and if its true what on the motor was different to change the compression ratio?
