IDF Carb Tuning Guide
- maytag
Re: IDF Carb Tuning Guide
I have a question related to fuel pressure regulators, and it most closely associates with this old thread. So I;m resurrecting it.
I'm a little confused by the info above, because the way I understand pressure regulators, if you put the regulator between the pump and the first carb, you are only regulating the pressure between the pump and the regulator, and NOT the pressure at the carbs. the fuel to the carbs effectively becomes just part of the return line at that point.
Unless you are eliminating the return line?
The comments above about blocking the return and then drilling it with a small hole seems to create a situation where the size of that hole is what is determining your pressure, not the regulator.
to my understanding of regulators, the "after" photo posted by Mighty8, with the new location should be correct.
someone help me with what I'm missing here?
Thanks.
Thanks.
- engineerted
Maytag,
Regulators regulate the pressure down stream. If the return line has less restriction than the two needle valves in the carburetors then you will not build pressure to flow into the carb fuel bowls. There is no need for a return line on a low pressure pump for IDFs. The only benefit of the return line is that it will keep a cooler supply of fuel coming to the carbs at the cost of the pump working harder all the time, plus it will filter all of the gas in the tank over and over again. So, if you want to keep the return line, put an inline restrictror or a 1-1/2 to 3 psi check valve.
Ted
Ted
Ted
So Ted, if you don't have a return line will an electric fuel pump burn out if the needle valves at the float bowls are closed? Or would I have to research whether or not a particular universal electric fuel pump has an automatic shut off feature?
- maytag
engineerted wrote:Maytag,
Ted
Thanks Ted!
you just gave me all the excuse I needed to eliminate that return line!
- engineerted
Ron, No they are self regulating and self relieving.
Ted
Thanks Ted, you just helped me solve a problem with a temporary fuel supply on a motorhome I need to move 8 miles.
PS. Self regulating and self relieving sounds like me drinking a lot of coffee on a long drive.
- maytag
well, other than the self-regulating part... it sounds like a bunch of us on the golf course too!
wait.... that was a different thread....
deliver a solid 3 psi at WOT <<<< what does WOT stand for
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- maytag
you probably know it as "WFO"fiat218 wrote:deliver a solid 3 psi at WOT <<<< what does WOT stand for
WOT = Wide Open Throttle.
lol ok, got itmaytag wrote:you probably know it as "WFO"fiat218 wrote:deliver a solid 3 psi at WOT <<<< what does WOT stand for
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- maytag
Does anyone have any data like that referenced above? I'd love to benefit from the work someone else has already done (rather than reinventing the wheel) to determine which horns and filters I should use on my motor.sptcoupe wrote:Ace - can you post that chart showing the flow increases/decreases through the various horn shapes we typically put on or carbs? I think this is an important element in getting the max out of your carbs. I know when we were experimenting with the FI on the coupe, the dyno showed up to 3 RWHP differences between horns! That is a lot. We ended up doing the custom horns in accordance with that chart, and got the best results that way. I won't be at our home in Dallas for another week, so maybe you can put it up on the this thread? Thanks.
Or tell me what y'all are using?
Jeff's car is using custom made super short air horns. The reasoning behind this is that the amount of space above the air horn (head room) is just as important as the horn's shape. There is only about 1.75" inside the air box to work with, so these horns were made 0.45" tall, leaving a head room of about 1.3" See them here: Weber 44IDF Air Horns
For shape, you certainly want a fully radiused horn. Most horns are poorly matched to he carb throats, blending is ideal, or even the type of horns that are machined to go into the carb throat behind the choke.
Also, you want your air correctors to be at the same height as the air horns. Some of them are buried down in the carb, others have extensions so they rise up off the carb body. Its a slight design change and the effect is small but having the air correctors at the same pressure as the throats is ideal.
Length of horns has nothing to do with increasing airflow or reducing restrictions. A long horn flows just as much air as a short horn. Where length is important is with tuning your intake runner length for your engine. This is why there are hundreds of different opinions for hundreds of different engines explaining that X engine made Y more power with Z air horns but putting Z air horns on a Fiat motor may not be the best solution. Where do you want the power to be, up high or down low? Do you have carb spacers? All of these factors are important.
Finally, the number one thing, get cool air into those carbs. If you're sucking in engine bay air, you're leaving power on the table. Not only are you tuning your carbs for hot air, you're tuning the ignition and everything else for hot air.
So how do u get fresh air to thempastaroni34 wrote:Jeff's car is using custom made super short air horns. The reasoning behind this is that the amount of space above the air horn (head room) is just as important as the horn's shape. There is only about 1.75" inside the air box to work with, so these horns were made 0.45" tall, leaving a head room of about 1.3" See them here: Weber 44IDF Air Horns
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
There are some pictures of the cold air box on the coupe in the "Performance" thread, dated January 15, 2012. Picture # 3 shows it best. The air is taken from in front of the radiator, routed through an enclosed filter box with a K&N filter, then into an air box that utilizes the room available under the hood to the max, and delivers the air from the side, right between the carbs and over the horns. All custom made.
I have a great chart that shows the air flow of various horns shapes, tested on an air flow bench. If someone will give me their email address, I will send them the chart that shows the different air flows on various horn shapes/heights, and you can post it for everyone. I just don't know how to make it work for some reason.
I had three custom sets of horns made for the coupe, all radiused. The tallest made the least HP, the shortest, the most. As I recall, about a 3 RWHP difference on the dyno.
When we fitted the cold air system, I had to go a full step richer in jetting. So after many dyno runs, I have concluded that the space over the horns is more important than the height of the horns (if they are properly radiused. Ideally, you should have as much space over the horns as the width of the chokes - so for 40 IDFs, 40mm would be ideal) and cold air allows you to get more fuel in the cylinders and develop a lot more HP.
I haven't run the coupe on a dyno since I put the cold air box on, but a whole step richer is no doubt a significant gain. I'll post the comparison results (with and without the cold air) when I get to a dyno in October.
Do u have a photo of your set up, thankssptcoupe wrote:There are some pictures of the cold air box on the coupe in the "Performance" thread, dated January 15, 2012. Picture # 3 shows it best. The air is taken from in front of the radiator, routed through an enclosed filter box with a K&N filter, then into an air box that utilizes the room available under the hood to the max, and delivers the air from the side, right between the carbs and over the horns. All custom made.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
