Distributor number
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: Distributor number
Post by RoyBatty »
I am finding this a bit strange.
I have the dual points distributor with no vacuum advance and the mechanical advance is below the contact breaker plate.
According to my discussion with the guys at Pertronix, their kit will work with my setup.
Can we see the image you sent them Ken?
Roy
kensmith
Post by kensmith »
RoyBatty wrote:I am finding this a bit strange.
Roy
http://i12.photobucket.com/albums/a205/ ... tor003.jpg
http://i12.photobucket.com/albums/a205/ ... tor002.jpg
http://i12.photobucket.com/albums/a205/ ... tor001.jpg
http://i12.photobucket.com/albums/a205/ ... tor004.jpg
RoyBatty
Post by RoyBatty »
I hate p-bucket!
I tried to view your images and it just isn't working.
Yes, I do have an account.
And out of curiosity I went out and wiped off the base of my distributor.
The number on mine says its a S144CBY.
Which is a good number according to the Pertronix catalog.
chrisfiat
Your car is a: 1976 124
Post by chrisfiat »
here are the pics of my install the pertonix part number is mr-ls1
no vac advance, formerly dual point dist, 1976 model year
http://i838.photobucket.com/albums/zz30 ... 011759.jpg
http://i838.photobucket.com/albums/zz30 ... 011757.jpg
http://i838.photobucket.com/albums/zz30 ... 11759a.jpg
kensmith
Post by kensmith »
RoyBatty wrote:I hate p-bucket!
Here are the number on mine and they said it won't work but for $300+ they could make up the unit:
S144RY
401R1 401P5-8D
manoa matt
Post by manoa matt »
Send me your distributor and the unit and I'll make it work for $150. Haha, just kidding. All Pertronix would do is drill an extra hole in the "C" shaped mounting plate so a screw can pass through and thread into a hole in the points mounting plate. However as others have stated it will work, and I don't even think drilling an extra hole would be necessary.
A 1976 and a 1978 are both dual point models and if it fits a 76, it will fit a 78. The 76 and 78 are the same exact distributor with the same advance curve, the 78 has a higher serial number as it was manufactured 2 years later...only difference.
Ken, as with many aftermarket parts, (shocks are a good example) many times the manufacturers don't know and can't confirm what cars their parts fit. Or even that the parts have physically changed despite a name change.
RoyBatty
Post by RoyBatty »
The Pertronix app guide lists the S144 distributor as one that will work.
Go for it Ken.
Buy two and I'll install both. One for you and one for me. ;)
normark
Your car is a: 1969 124 Spider
Post by normark »
I have the same problem. I have a S144RY and waiting to receive a Pertronix kit.
Say, where do I have to drill the hole in the mounting plate? Or perhaps it's self explanatory when I get the kit
