aux shaft
Re: aux shaft
just out of curiosity, what broke the old shaft?
royce71
Re: aux shaft
Post by royce71 »
I don't know, the car had an electric pump when I bought it with the mechanical still in place. I haven't started the car in a few years and wanted to replace the pump and when I took off the pump I noticed there is no lobe. I think I am just gonna stay with the electric.
Re: aux shaft
you still need the aux shaft even with an electric pump. So the block in the pic is not in the car?
majicwrench
Re: aux shaft
Post by majicwrench »
I would start with a aux shaft that you KNOW is out of the proper engine, there are tons of them around. Get the right piece.
royce71
Re: aux shaft
Post by royce71 »
This is where the shaft was broken next to the other shaft.
Can such a short shaft cause tne pulley to wobble slightly?
narfire
Re: aux shaft
Post by narfire »
And the short broken part is where? The one we had to deal with looked identical. It was contact from the #2 rod at a start up. Ended up dropping the pan/lifting the engine to get the back part out.
Chris
royce71
Re: aux shaft
Post by royce71 »
I already took off the pan to check the pump and beat out a dent, the baffle was cut out of the pan so I guess it was already taken out.
royce71
Re: aux shaft
Post by royce71 »
Am I ok using the broken shaft with an electric pump?
Re: aux shaft
no, it doesn't have the second bearing for support.
narfire
Re: aux shaft
Post by narfire »
Have you had a chance or are able to look in the shaft passage-way? Mirrors or pull the rad I guess. What does the back bearing surface look like? I thinks the end of the broken shaft might have bashed against the surface,perhaps scoring it or something preventing a new one to go in. If you are going to use an electric pump, many will cut the end of the shaft(lobe) off and drill out the oil passage to accept the oil passage plug like on the end of the lobe. Some will tap and screw a plug in as well. Then there is never going to be an issue contacting the #2 rod. and you will still have the two bearing surfaces.
Chris
royce71
Re: aux shaft
Post by royce71 »
You're right, I felt through the fuel pump access and there is a gouge in the bearing and as soon as I felt it a small piece fell off. Is it possible just to grind it down a little or do I need to replace the bearings. Can I do it with the engine in the car? Thanks for the tips.
What is the worst that can happen from leaving the broken one in?
narfire
Re: aux shaft
Post by narfire »
I'd be looking at replacing the bearings. Check the various vendors for that part. I'm thinking when we dropped the oil pan and slid it out of the way and rotated the enging a bit to get the #2 out of the way,we had access to the aux shaft passage. Now I've never replaced an aux bearing and hope someone here can better answer that part if it can be done from below.
I'm thinking if you leave the broken one in, you have the shaft supported buy only one bearing surface. The broken end will not track straight , flap about,adding more strain to the single bearing,oil pump gears ect.
Chris
royce71
Re: aux shaft
Post by royce71 »
Ok it looks like this engine is going to the machine shop. Thanks for the help.
Re: aux shaft
those aux shaft bearings have to be reamed to the proper diameter once they're installed
royce71
Re: aux shaft
Post by royce71 »
About how much should I expect to pay for them to press and ream them?
