What is this and where should the tube from here go to?
kmead
Your car is a: 1969 850 SC 1970 124 SC 85 X19
Re: What is this and where should the tube from here go to?
Post by kmead »
So Cal Mark wrote:throttle dashpots do not control or affect Nox. Nox is formed at high cylinder temps, not during decel.
Mark is correct, the throttle being held open is intended to ensure some airflow and reduce hydrocarbon (HC) and carbon monoxide (CO) under a lean burn condition that can occur with the throttle plate closed.
My memory failed me and I didn't check my facts. Either way, it is a system intended to reduce emissions.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
