I had a similar problem after replacing my fuel tank. Didn't tighten the float fitting down tight enough, and started to splutter going up hills or round corners.
Topped up the fuel and tightened down the float plate, and voila.
Also check the tank by removing the float plate and looking inside with a torch. I had another fuel-related problem where the car would conk out every once in a while. It would then start again shortly thereafter. Turns out that large flakes of rust in the tank were being sucked up against the pipe (missing its mech filter) and preventing flow. Once suction pressure was removed (when it conked out) the rust would fall off and let the car start and run again.
Help Please!!
- perthling
Re: Help Please!!
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
Perthling
Re: Help Please!!
" . . . Also check the tank by removing the float plate and looking inside with a torch. . . ."
Would that be a propane or a butane torch?
Alvon
Alvon
- perthling
Re: Help Please!!
If you can't find a torch, a flare works just as well...
(Safety disclaimer: vehicle owners inspecting fuel tanks using a flare do so at their own risk.)
Perthling
Perthling
