Weber 32/36 DFEV Upgrade: Game, but Ignorant
DocGraphics
Your car is a: 1978 124 spider
Re: Weber 32/36 DFEV Upgrade: Game, but Ignorant
Post by DocGraphics »
Good to know, will do.
Don Raugust
opus10583
Your car is a: 1978 CS1
Post by opus10583 »
And we're back to:
Can I replace the electronic bits in a vacuum advance FIAT distributor with the Petronix Ignitor I already have?
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
manoa matt
Post by manoa matt »
Well, the two systems are both "lobe sensing units" and each have two wires. But you could fry something in the process of learning. If the Pertronix unit gets fried, thats an expensive lesson.
fiat218
Post by fiat218 »
back to my upgrade
i have notice that on my 1980 spider, being a auto tranny, it does not shift it gears, it possible the module is run by a vacuum line, i do have one that i have not really did any checking to see where it goes, and i am not good at explaining things here,
but if the line i see is the line to the tranny,where would it hook up to so that way the tranny is shifting normal in drive
thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
the modulator vacuum line must go to manifold vacuum, and just as important, the detent cable HAS to be connected
fiat218
Post by fiat218 »
thanks mark. vacuum line is not connected, now i know where it goes, does not matter where on the intake.correct?
the detent cable HAS to be connected? i assumed that it already is connected, all i did was change the intake and only cable on the previous was the throttle linkage, unless i am not understanding something
ALL IS WELL tranny shifts
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
