Coming Soon-IR FI system
We're close to having an aftermarket FI system that uses an individual runner intake with 4 throttle bodies. It will be a complete system that comes with a basic map that features a self-learning tuning program. Stay tuned for details in the coming weeks!
- divace73
Re: Coming Soon-IR FI system
looking foward to that....
Cheers David
see my >>You tube channel<<
- Your car is a: 1969 Fiat 124 Sports AC coupe
Can we assume it will be downdraught based to clear the MC?
the manifold will have an approximate angle of 20 degrees to clear the brake booster
- divace73
Hi Mark
I'm assuming it will be fine with the RHD cars? I have the coolant overflow bottle where the brake bootser use to be, but that can always be moved.
Cheers David
there shouldn't be any issues with rhd. We sent the first intake to Spain and it fit fine although the owner had his own throttle bodies.
- divace73
Hi Mark
Update on the Throttle bodies....
Cheers David
I probably won't have updates for another week, although I can say that this system will work with our distributorless ignition system. Using the two systems together will alleviate the need for a custom crank pulley and sensor.
- divace73
Would we be able to use it with Megasquirt? I have just had the 36-1 wheel adapted to my pulley.....
Cheers David
yes, it will work with megasquirt or any crank sensor arrangement
- kbee00
- Your car is a: 1972 Spider
Hi Mark,
I am in the process of adapting an FI system to my '79 - but if your system is "better", then all the better. One thing that concerns me is the cost. Custom systems usually are quite expensive - can you give us some sort of idea of the cost of your system and what it will all include? Will your system adapt to a carb'd car?
Thank you for continuing to support our little community. My 15 yr old daughter has already been reading on this forum and her eyes on my restoration - "when it will be done daddy?".....you probably know the drill.....
Loren
Loren
1980 Strada (crushed)
1982 Strada (parts for the 1980 then crushed)
1966 MGB (E-Prod race car - sold)
1968 MGB (Targa Newfoundland - totalled)
1979 Spider (current vintage restoration)
1972 Spider daily driver
It's just a bit premature to quote prices. We're working on different manifold options at this point and until we settle on the particulars, pricing won't be available. The advantage over a megasquirt system will be self-tuning. Rather than spending days, weeks, months building a map, this system will self-learn as you drive.
- kbee00
Sounds interesting Mark. Looking forward to the next update.
