Engine Identification
Mike_S
Post by Mike_S »
It's been a while since I played with the old Fiat, but now it's really time to get the motor freshened up.
The only issue I have is trying to figure out what is in this thing. The only markings on the block are cast into it on the intake side of the motor, over the motor mount: I see Fiat 138-AR1 and Lancia 4466158. The only reference i can find for this says it belongs in a Strada 125TC?
The head has a casting number 4371507, can't see any other identification, which seems to say it's off a late fuel injected Spider.
I believe it's a standard 2L TC, but was just wondering if there's anything I should be wary of.
Any thoughts as to the block origin would be appreciated.
maytag
Re: Engine Identification
Post by maytag »
Mike:
look further down the block, on or next to the oil-filter mouting pad, above the motor-mount: you'll see a code stamped (not cast) into it. that'll be the descriptor on the block.
like this one:
Mike_S
Post by Mike_S »
Thanks, I finally found it.
Engine: 132-C3 .03 1
Cylinder Head: 4371507
Seems to be a standard 80's 2l fuel injected motor and head. Doesn't look like anyones messed with it yet, who knows this may be it's first rebuild.
TommyClocks
Your car is a: 1975 124 Spider 1970 Corvette Roadster
Post by TommyClocks »
I was curious if there is any correlation between the numbers stamped on the block and the VIN. I would like to know if my car still has the original motor, please let me know if there is a way to tell.
Tom
---Tommy
1975 124 Spider "Jeanie"
1979 X 1/9 "Natalie"
maytag
Post by maytag »
Mike_S wrote:Thanks, I finally found it.
132C3.031 is the following:
DOHC 1995cc
bore/84.0mm
stroke/90.0mm
C/R =8.1:1
valve timing=5-53/53-5
F.I. California
HP = 102
That head casting # is also consistent with this motor series.
KalamazooJohnny
Your car is a: 1976 spider 1977 spider 1965 1100D
Post by KalamazooJohnny »
Is there a list somewhere that deciphers the numbers stamped there telling what numbers mean what engines?
"Get used to people calling it an MG. Hardly anybody recalls Fiats, but people remember MGs because they once saw one on fire." -Corey Farley, Autoweek January 20, 2003
76spider
77spider
65 1100D
manoa matt
Post by manoa matt »
