best looking fiat engine pics?
azygoustoyou
Re: best looking fiat engine pics?
Post by azygoustoyou »
Tony,
You could get some Fusion paint and paint it.
azruss
Post by azruss »
That cone filter is made by Airaid in Phoenix, AZ. it is the smallest cone filter they make (6" i think). They wont sell you direct but wil put you in touch with a dealer. I had to make an adaptor bracket.
several of the fiat supply houses carry K&N.
mdrburchette
Post by mdrburchette »
That filter looks just like the ones we use on our gokart engines, except ours are a tad smaller.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
131
Post by 131 »
grittracing wrote:also can someone please ask these Distributor cap manufactures . to use some other colors other the brown !
It wouldn't take much to paint it whatever colour you wanted!
Mick.
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
Here is the coupe in its current trim. We continue to try to improve the HP, and are adding a custom made TB manifold that we have worked with Mark to develop and get just right. It tilts the TBs away from the engine by 22.5 degrees, which straightens out the intake runners quite a bit which we hope will improve flow velocity. It also gives us more room to fit the injectors between the cam tower and the fuel rail. We have also altered the shape of the air box by smoothing out all inside edges, and we are improving the exhaust system by eliminating some "ledges" in the fitment between the header and downpipe (the header is Mark's, the down pipe is custom), and adding custom, 3", hi-flow, baffled exhaust tips. Other improvements are a new throttle linkage to ensure accurracy and consistency in the throttle plate movement, and we have moved the ignition towers forward of the exhaust header and out of the corner where all the hot air was trapped. Have installed a reduction starter, and a 130 amp alternator (the 95 amp I had on the coupe is going on the spider). We'll be putting some gentle miles on it for the next few weeks, and then it will be back to the dyno to re-do the fuel map and see if we get more than the 150.5 we have in its current trim. Will keep you posted.
grittracing
Post by grittracing »
Yeah, I painted on red and another black not sure witch I will use yet. I painted the old one. yellow to match the fan and belt guard. that looked bad ! I would like the contact info to the manufacture please and its here in the states wow !
ITA124
Your car is a: 1976 Fiat 124 Spider
Post by ITA124 »
Just finished some small mods. Need to remove tool in the cam valley
Paul
Fiat 124 Spider (Big Red Car. So my son tells me)
Toyota Corolla AE86 (Fiat as a daily driver? Not)
Fiat 128 Rally (Why did I sell this car?)
Fiat 124 AC (An iron ore waffle shaped like a 124. Donated to Sims)
Fiat 128 SL (First fiat)
Curly
Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Post by Curly »
Very nice job there Paul, we're lucky to have right-hand-drive versions bacause that allows us to use side-draft Webers :D .
Here's my AC coupe engine bay with its 1600.
... and SPYDUH's 2-litre version.
ventura ace
Post by ventura ace »
You Aussies always do such a great job of keeping everything neat and tidy in the engine bay!
Paul, where do you get those straps / clamps that fasten the lines and hoses to the firewall, fenderwells, and elsewhere?
Alvon
spiderrey
Post by spiderrey »
My 70 2 liter with the 44,s
stock 1438 built for the 68
2 liter waiting for manifolds
maytag
Post by maytag »
Rey:
Are those PAINTED cam gears?
how does that work-out? 'cuz it looks sharp!
spiderrey
Post by spiderrey »
Yes, they are painted. My son thinks it looks aweful. I painted them yellow to match the wires and dip stick. Just a touch of color without going overboard. Paint is same engine paint that I use on the motor. Cam gears are from Miller, the only thing I didnt like about them was that the ones I received were pretty worn in the teeth compared to the cores I sent in. I was going to ask if he would wap them out for me if I sent him good cores again. i just never got around to contacting him. I tried to get as little paint on the teeth as possible figuring it was going to wear off anyway. The paint made the center piece a very tight fit when reassembling the gear.
spiderrey
Post by spiderrey »
oooooooooooops
