Exhaust Shop Issues
Mark_vaughn
Exhaust Shop Issues
Post by Mark_vaughn »
Hey Guys. I need a liitle help.
I replaced my exhaust header with one I purchased off ebay, but it doesnt have the second part, collector tube I think. I figured the muffler shop could fab something up that would work for the money I was saving.
Well, they said they could but when they looked at it they rejected it because the pipe wouldn't let the steering idle arm move, so no right hand turns.
Could someone post a picture with their 4-2-1 system from below so I can show them what I need. Or if anyone has a spare 2-1 part that would work, I am interested.
HELP!!!
P.S. No cops stopped me on the drive around town. I guess Arkansas is the home of trucks with glass packs, so they would be stopping everyone.
mdrburchette
Post by mdrburchette »
Any specific year model, Mark? My 72 has the 4-2-1 but it may not be routed the same.
Mark_vaughn
Its a 77 w/ a 1800 engine. It didn't have the 4-2-1 originally, but I didn't think they made any big changes between these years.
From the pictures I have seen it is going to be tight clearance with the steering. If someone could take a look at theirs with the steering at full right hand turn lock and see what it looks like clearance wise.
Thanks everyone!!
are you using a cast iron exhaust manifold or a tubular exhaust header?
Mark_vaughn
Steel tube.
I can tell you that pipe is one of the biggest challenges to fitting a tube header on a Spider. We put a lot of research into our system to get that pipe to fit and clear the idler
mbouse
Post by mbouse »
glad you made it there with no BLUES involved.
Mark_vaughn
So anyone have a suggestion?
mdrburchette
Mark, this is what I came up with: When I stick my finger between the tie rod end and the muffler, only my index finger to my first knuckle can squeeze in...about 1/2 inch clearance. Is this what you're looking for?
Mark_vaughn
YES!! Thank you. It looked like a very tight clearance. I think I will have to find another muffler shop. Too bad b/c this one was so close.
More cop dodge ball.
Mark_vaughn
On second look, I think I have figured it out. I have a heat shield on the tie rod ends that takes up another 1/2 inch around it. That may be why they didn't think it could be done.
mdrburchette
A heatshield? Well, that's something to think about since the tierod end is so close to all that heat.
brad131a4
Post by brad131a4 »
Mark do you have a picture of the top of the header. I have a header with the down pipes that slide onto the two that are ending. Is this what you have. If so if you want to pay for shipping I'd send it to you so that the muffler shop could copy it for you as I would like to keep it for my car.You can email me at abcherriges@comcast.net if this is something that would work for you.
