Head bolts
nibbes123
Your car is a: 1979 Fiat 2000
Head bolts
Post by nibbes123 »
Would someone be able to help me on this matter on weither to install head bolts in block with out anything on the threads or put something on the threads and torque them down.Also anything on the head gasket like grease or install dry.
Nick :?
Re: Head bolts
I'd clean all of the threads in the block and on the bolts, then use a light oil or antiseize. As for the gasket, most modern gaskets go on dry
nibbes123
Re: Head bolts
Post by nibbes123 »
Thanks Mark for the reply.
Nick
