To work on getting this '84 spider started, should the timing mark be at 0 degrees (TDC) or set at 10 BTDC?
Otherwise, get cam pulleys to set on their marks;
Aux pulley set at about 1:00 position, and disributor rotor set to cylinder 4 position.
Should this cover it, at least until I can get it going and hook up a timing light?
I really should go ahead and do this inconjunction with a new belt (and maybe new tensioner bearing, from what I have read on here?), but I am anxious to get the car running first, just to hear the state of things.
Static timing settings for 2L FI
Re: Static timing settings for 2L FI
I think FI is factory set a 5 degrees but I don't see a problem with 10. Don't forget to set it with the vacuum advance hose disconnected.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
I start off at 0 deg.(cam wheel holes at the marks for tdc and crank mark on the long pointer(tdc/0deg)and the dist rotor about to contact #4 pin in the cap. Once it is running,then turn the dist till the 10 deg point is lined up with the mark on the crank wheel.
Getting close eh... I can't wait
Watch your hand on the manifold ,it gets hot quickly.. a stubby 17mm works best down there
