learn something new
puddin
learn something new
Post by puddin »
i have a 78 and pulled out all emissions stuff changes to a hi perf air filter and didn't know what to do with the pvc line. so i put a pvc valve in the tube and ran a 5/16 vac line to the int manifold. wow -- noticed that it was sucking so hard that the oil fill cap was hard to get off. and noticed a 10-20 psi drop in oil press. -- guess i'll just punch a hole in the chrome air cleaner and let blow by in the carb.. any better ideas.
digitech
Re: learn something new
Post by digitech »
I've gone around and around with this, trying to install a modern pcv system - I've been told to leave well enough alone and at this point, I have to agree. You would really need to install the pcv valve into one of the valve covers and partially baffled as well, then connect into manifold vacuum. And I don't think there is an area of the valve cover that would offer adequate clearance from the cam.
mdrburchette
Post by mdrburchette »
If you can't vent it to the air cleaner, why don't you just install a breather for it? You'll probably want to use a shorter hose.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
puddin
Post by puddin »
yup best way was to punch a hole in the air cleaner and let her blow.
also noticed oil press is still kinda low 20 psi at idle-- not sure if the oil filter has something to do with that, i change the oil two weeks ago and used a fram filter and noticed the oil press was lower. less resistive i guess also used penzoil instead of catrol gtx. weird huh.
majicwrench
Post by majicwrench »
Nothing wrong with 20lbs oil pressure at idle. FIlter would not cause pressure drop. Probably a little difference viscosity. Wouldn't worry bout it.
puddin
Post by puddin »
could be oil 10w 40 castrol gtx had 40-50 psi now penzoil 10w40 has 20 psi -- thought colder weather would increase press. since fluid is thicker... i dunna know
mdrburchette
The filter could be the culprit. I had a problem with low oil pressure after changing the oil in one of my daily drivers. I replaced the oil filter and problem solved.
If the oil pressure light doesn't come on, you should be good to go though.
puddin
Post by puddin »
i pulled the oil switch and put in a sun oil press gauge for $25-- had 50psi and watched it drop after 4 months of daily driving hope the pump is going... i highly reccomend the press guage -- for $25 the idiot light isn't going to save your motor.
puddin
Post by puddin »
see FRAM OIL FILTERS SUCK for the answers to this problem
