79' Intake Manifold off, 1800 Conversion started!
Re: 79' Intake Manifold off, 1800 Conversion started!
if you remove the exhaust pipe, there is no need to deal with the crossover passage in the head
Is removing the pipe a better idea? I wonder if I could find a plug though to fit the hole left by the pipe in the manifold?So Cal Mark wrote:if you remove the exhaust pipe, there is no need to deal with the crossover passage in the head
baltobernie wrote:If you're going to re-attach the breather hose to the air cleaner, order one of these, too. It goes inside that hose.
This prevents a backfire from igniting crankcase vapors.
What happens to the breather hose if you don't use the stock air cleaner and install one of the box types? Do they have a port for the hose or do you have to fabricate something? Or what are the alternative hookups for the breather?
I decided not to remove the pipe as it didn't want to budge after liberal amounts of wd-40, so I sandwiched the steel plate between the pipe flange and the head.
Another thing, should I use any gasket sealer on the new intake manifold gasket?
I would, especially around the water ports. And don't use rtv
What kind of gasket sealer would you recommend Mark? Thanks.So Cal Mark wrote:I would, especially around the water ports. And don't use rtv
I would suggest Permatex Hi-Tack
Does anyone know how this vacuum port comes off? It has a allen head fitting but won't turn. Thinking about just cutting it off with my dremel.
there are two allens, one external, the second below the first
