1980 Fiat 2000 FI Timing
- Your car is a: 1980 Fiat spider 2000
Just want to make sure before I time my engine. When the engine is at TDC the rotor will be pointing at the number 4 post. Then you hook the timing light to the number 1 spark plug wire?
Re: 1980 Fiat 2000 FI Timing
# 4 plug wire
I thought so. I haven't tuned a Fiat since 1978.
you can set ignition timing on either 1 or 4, those are alternate cylinders
