Head bolts
- SLOSpider
Head bolts
Anything special I need to do to the head bolts like put RTV on the threads when installing my head?
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- SLOSpider
Re: Head bolts
also coming up with 2 different torque values? maybe should split the diference at 59 ftb?
1975 124 Spider
- Your car is a: 1976 124
Re: Head bolts
clean threads in the block clean threads on the bolts, lightly oil bolt threads......NEVER use sealant on head bolt threads
- Your car is a: 1969 Fiat 124 Sports AC coupe
Re: Head bolts
There are 2 types of head bolts. The earlier cars had torque to a given FtLb rating.SLOSpider wrote:also coming up with 2 different torque values? maybe should split the diference at 59 ftb?
Later headbolts were stretch type or torque angle type. I.e. torque down to a certain value, then turn another 45 degrees from this value. This type does not require a retorque the earlier type does. Bolts need to be dipped in engine oil then allowed to sit for a while and drip/drain before use. and do make sure you chase the threads in the block first.
Are your head bolts waisted? what does it say on the head of the bolt?
Re: Head bolts
Who, who who's Ace124?? I once knew a Ventura Ace, wonder if it's the same person...
Re: Head bolts
Not Ace Ventura.gary124sport wrote:Who, who who's Ace124?? I once knew a Ventura Ace, wonder if it's the same person...
ACE 124 was a number plate i had on my 1st 124 many years ago
Im also from down under where they ride kangaroos and throw bent sticks that come back.
- Your car is a: 1981 Spider Turbo - missing the turbo
Re: Head bolts
ACE124 - Nice to see you here
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
- SLOSpider
Re: Head bolts
Ok thanks! I did clean the bolts, chase the block threads, coat and drain them in oil, oil the washers to have a smooth torque value and set them at 56 ftb. Ill run it for a bit and re torque in another 500 or so miles. On re torquing do you back them off first as I have read or just continue to try and tighten? Got it allo running last night now to put the hood on and bleed rear brakes from a hose replacement.
1975 124 Spider
